Sub ShowPicture()
Dim r As Range, ra As Range
Dim imgIcon As Object
Dim obj As Object
With Worksheets("Sheet1")
Set ra = .Range("B1", .Range("A65536").End(xlUp).Offset(0, 1))
For Each obj In ActiveSheet.Shapes
If Left(obj.Name, 4) = "Pict" Then
obj.Delete
Next obj
For Each r In ra
Set imgIcon = ActiveSheet.Shapes.AddPicture( _
Filename:="D:\" & r.Offset(0, -1).Value & ".jpg", LinkToFile:=False, _
SaveWithDocument:=True, Left:=r.Left, Top:=r.Top, _
Width:=r.Width, Height:=r.Height)
For Each r In ra
If r.Offset(0, -1).Value <> "" Then
Sub ShowPicture()
Dim obj As Object
obj.Delete
Next obj
For Each r In ra
Sub ShowPicture()
Dim obj As Object
obj.Delete
Next obj
For Each r In ra
