Sub GetNumbers()
Dim uColumn As String
uColumn = "A"
Dim i As Long, j As Long, r As Range
For i = 2 To Range(uColumn & Rows.Count).End(xlUp).Row
Set r = Range(uColumn & i)
Dim tmpStr As String
tmpStr = vbNullString
For j = 1 To Len(r)
If IsNumeric(Right(Left(r, j), 1)) Then tmpStr = tmpStr & Right(Left(r, j), 1)
Next j
r.NumberFormat = "#,##0"
r = tmpStr
Dim rAll As Range, r As Range
Dim i As Integer, t As String
With Sheets("Sheet1")
Set rAll = .Range("a2", .Range("a" & .Rows.Count).End(xlUp))
rAll.Offset(0, 2).NumberFormat = "#,##0.00"
For Each r In rAll
t = ""
For i = 1 To Len(r)
If Mid(r, i, 1) Like "#" Or Mid(r, i, 1) = "." Then
t = t & Mid(r, i, 1)
r.Offset(0, 2).Value = t
