Dim DrugRange As Range
Dim LotRange As Range
Dim FillLot As Range
Dim i As Range
Set DrugRange = Range("List!B:F")
Set LotRange = Range("List!F:F")
Set FillLotRange = Range("FillForm!C8")
i = Application.WorksheetFunction.Index(DrugRange, Match(FillLotRange, LotRange, 0))
With Sheets("List")
.Range("i").Value = _
Sheets("FillForm").Range("C12").Value
Dim FillLotRange As Range
Dim i As Range
Set LotRange = Range("List!B:B")
With Application.WorksheetFunction
Set i = Sheets("List").Range("F" & .Match(FillLotRange, LotRange, 0))
With Sheets("List")
i.Value = Sheets("FillForm").Range("C12").Value
Dim FillCodeRange As Range
Dim CodeRange As Range
Dim i As Range
Set CodeRange = Range("List!B:B")
Set FillCodeRange = Range("FillForm!C8")
Set i = Sheets("List").Range("C:F" & .Match(FillCodeRange, CodeRange, 0))
With Sheets("List")
i.Value = Sheets("FillForm").Range("c4:f4").Value
ลองเป็นแบบนี้มันใช้ไม่ได้ค่ะ
i = .Match(FillCodeRange, CodeRange, 0)
With Sheets("List")
.Range("c" & i).Resize(1, 4).Value = Sheets("FillForm").Range("c4:f4").Value
