Sub Compare_Data()
Dim iCount As Integer, rCount As Integer
Dim j As Integer, rAll As Range
Dim r As Range, lMatch As Long
With Sheets("Data")
Set rAll = .Range("A2", .Range("A" & .Rows.Count).End(xlUp))
rCount = rAll.Count
For j = rCount To 2 Step -1
iCount = Application.CountIf(Sheets("Database").Columns(1), rAll(j))
If iCount > 0 Then
rAll(j).Resize(10).EntireRow.Insert
Next j
Set rAll = .Range("A2", .Range("A" & .Rows.Count).End(xlUp)) _
.SpecialCells(xlCellTypeConstants)
For Each r In rAll
iCount = Application.CountIf(Sheets("Database").Columns(1), r)
If iCount > 0 Then
lMatch = Application.Match(r, Sheets("Database").Columns(1), 0)
r.Offset(0, 1).Resize(iCount) = Sheets("Database") _
.Range("b" & lMatch).Resize(iCount).Value
.Range("b2", .Range("b" & .Rows.Count).End(xlUp)) _
.SpecialCells(xlCellTypeBlanks).EntireRow.Delete
