Excel query 3
sna
Excel Ver: Excel 365
Excel query 3
Post by sna »
Dear all,
I need your input to find total by group whose total nearest
The data in column A,B n answer in the next
Pls find the attached
Thanks
Re: Excel query 3
:D Try this,
=LET(
 d,A2:B16,
 cats,UNIQUE(INDEX(d,,1)),
 sums,SUMIFS(INDEX(d,,2),INDEX(d,,1),cats),
 MAKEARRAY(ROWS(cats),4,
   LAMBDA(r,c,
     LET(
       cat,INDEX(cats,r),
       sum,INDEX(sums,r),
       others,FILTER(cats,cats<>cat),
       osums,SUMIFS(INDEX(d,,2),INDEX(d,,1),others),
       diffs,ABS(osums-sum),
       match,FILTER(others,diffs=MIN(diffs)),
       pairCat,TEXTJOIN(", ",,match),
       pairSum,INDEX(FILTER(osums,diffs=MIN(diffs)),1),
       CHOOSE(c,cat,sum,pairCat,pairSum)
sna
Re: Excel query 3
Post by sna »
Thanks
