Text cleaning
sna
Excel Ver: Excel 365
Text cleaning
Post by sna »
Hi there
I need your input how to write formula to split date ,product and quantity apart
I attach a template
Thanks
Re: Text cleaning
D2=LET(s,SORT(TEXTSPLIT(SUBSTITUTE(B2,CHAR(32),""),","),,-1,TRUE),CHOOSECOLS(HSTACK(SORT(DROP(--s,,1),,-1,TRUE),TAKE(s,,1)),1,3,2)) Copy down
sna
Re: Text cleaning
Post by sna »
thanks it works.how to make it spill range?
norkaz
Excel Ver: 2013,365
Re: Text cleaning
Post by norkaz »
D2
=LET(b,B2:B8,a,MID(b,SEARCH("/",b)-4,10),c,TOCOL(MID(SUBSTITUTE(SUBSTITUTE(b,a,""),",",REPT(" ",50)),{1,50,100},50)+0,3),HSTACK(a+0,TRIM(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(b,a,""),c,""),",","")),c))
Bigcat9
Bangkok Thailand
sna
Re: Text cleaning
Post by sna »
thanks so much
