sna
Posts: 721 Joined: Tue May 05, 2020 8:18 am
Excel Ver: Excel 365
by sna » Sun Apr 18, 2021 12:02 pm
Hi Dear,
I come up with an issue how to add values in single cells but data type not consistent like space and = sign.
I also attached and excel template with result on column b
Thanks
sna
by sna » Sun Apr 18, 2021 12:03 pm
Here's the attached
by snasui » Mon Apr 19, 2021 11:46 pm
You can use this formula for example text in your attached file.
=SUM(FILTERXML("<t><s>"&SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(A3," kg","kg"),"="," ")," ","</s><s>")&"</s></t>","//s"))
sna
by sna » Wed Apr 21, 2021 7:31 am
Thank you
