Select yellow
sna
Excel Ver: Excel 365
Select yellow
Post by sna »
Hi there!
I would need your help regarding code to select only rows have yellow color.
I try to code but not working
Also attached template
Best wishes
Re: Select yellow
Try it
Sub DeleteYello()
Dim rg As Range, i As Long
Set rg = Range(Range("a2"), Range("A" & Rows.Count).End(xlUp))
For i = rg.Rows.Count To 1 Step -1
If rg(i).Interior.ColorIndex = 6 Then
rg(i).EntireRow.Delete Shift:=xlUp
sna
Re: Select yellow
Post by sna »
Thanks .I need select only yellow rows no delete
Re: Select yellow
:D The example code as below:
Dim strRg As String
For i = 2 To rg.Rows.Count
        strRg = strRg & "," & rg(i).Address(0, 0)
Next
Range(Mid(strRg, 2)).EntireRow.Select
sna
Re: Select yellow
Post by sna »
Thank you will update soon
sna
Re: Select yellow
Post by sna »
It occurs run-time-error '1004'
It highlight this part
sna
Re: Select yellow
Post by sna »
Here's an update
Re: Select yellow
:D The error occurred because not met condition. Adjust your code with below:
Dim strRg As String
Set rg = Sheets("Bakong").Range(Range("a2"), Range("a" & Rows.Count).End(xlUp))
If strRg <> "" Then
sna
Re: Select yellow
Post by sna »
Hi I test it but it still work nothing
Re: Select yellow
:D Please read my post #8 with carefully.
sna
Re: Select yellow
Post by sna »
I add this line if strRg <> "" Then
To check strRg value like in post #8 but still no luck
Re: Select yellow
snasui wrote: Tue Oct 13, 2020 4:42 pm The error occurred because not met condition.
:D The above is important information :!:
sna
Re: Select yellow
Post by sna »
Hi what is the condition behind?
I just need code to select row with yellow color
from column A to I only.
Re: Select yellow
:D Please check this statement. rg(i).Interior.ColorIndex = 6
sna
Re: Select yellow
Post by sna »
I check the code work but yellow here comes from conditional formatting.this file came from my friend so the code won't trigger.how can we handle this?I just realized this because he doesn't say color it is from conditional formatting
Re: Select yellow
:D Adjust with the code below:
    If rg(i).DisplayFormat.Interior.ColorIndex = 6 Then
sna
Re: Select yellow
Post by sna »
Thanks 🙏
sna
Re: Select yellow
Post by sna »
It is error this line
run time error '438'
if rg(i).DisplayFormat.Interior.ColorIndex = 6
Re: Select yellow
:D It not show this problem in my machine.
