rate p.a
sna
Excel Ver: Excel 365
rate p.a
Post by sna »
Hi Dear,
I have a bit hard related calculation rate per month to annum since the rate downloaded from a system mix with text not consistent so it is difficult to calculate.is there any formula to solve ?
Best Regards,
Re: rate p.a
:D Could you please give me a condition line by line of your data?
sna
Re: rate p.a
Post by sna »
Hi this is a new file with line by line narrative
Re: rate p.a
:D How do you know cells A3, A5 and A6 are multiplied by 100 before multiply by 12?
sna
Re: rate p.a
Post by sna »
Hi Dear
I Know it multiply by 100 since rate are at least 0.59% per month or 0.0059 .the rate not below this cap.
Best Regards,
Re: rate p.a
:D Try this,
B2
=LEFT(A2,FIND("%",A2&"%")-1)*IF(A2<0.59,1200,IF(COUNT(SEARCH("ក្នុងមួយឆ្នាំ",A2)),1,12))
Enter > Copy down
sna
Re: rate p.a
Post by sna »
Thank you 🙏
