External
sna
Excel Ver: Excel 365
External
Post by sna »
Hi
I need your help to find how many loan refinance greater than 5000$ and it's amount?
how many loan refinance less than or equal 5000$ and it's amount for both branch KPI and STG in Sheet4?
Best Regards,
Re: External
I don't know, do I get it right? If yes then follow this Can be viewed from the attachment
Key according to this
F1=USD,G1=KPI,H1=STG
F2=>5000
F3=<=500
G2:H3=SUMIFS($C$2:$C$11,$A$2:$A$11,G$1,$C$2:$C$11,$F2,$B$2:$B$11,$F$1)
sna
Re: External
Post by sna »
Thanks but I have three currencies.this is just for sample a two-currency transactions.I need both amount and number means I need sum and count.
Re: External
:D Could you please enter your correct results and attach file again?
sna
Re: External
Post by sna »
The expected result also provided in the template.is it possible to do with pivot table???
Best Regards,
Re: External
:D Try this,
  1. E2 *** If you have the exchange rate that needed to convert, you should create the converted column for easy to manage. ***
    =IF(B2="KHR",D2/4000,D2)
    Enter > Copy down
  2. G2
    =SUMIFS($E$2:$E$11,$B$2:$B$11,$F$1,$A$2:$A$11,$G$1,$E$2:$E$11,$F2)
    Enter > Copy down
  3. H2
    =COUNTIFS($B$2:$B$11,$F$1,$A$2:$A$11,$G$1,$E$2:$E$11,$F2,$E$2:$E$11,">0")
    Enter > Copy down
  4. I2
    =SUMIFS($E$2:$E$11,$B$2:$B$11,$F$1,$A$2:$A$11,$I$1,$D$2:$D$11,$F2)
    Enter > Copy down
  5. J2
    =COUNTIFS($B$2:$B$11,$F$1,$A$2:$A$11,$I$1,$E$2:$E$11,$F2,$E$2:$E$11,">0")
    Enter > Copy down
  6. G7
    =SUMIFS($E$2:$E$11,$B$2:$B$11,$F$6,$A$2:$A$11,$G$6,$E$2:$E$11,$F7)
    Enter > Copy down
  7. H7
    =COUNTIFS($B$2:$B$11,$F$6,$A$2:$A$11,$G$6,$E$2:$E$11,$F7,$E$2:$E$11,">0")
    Enter > Copy down
  8. I7
    =SUMIFS($E$2:$E$11,$B$2:$B$11,$F$6,$A$2:$A$11,$I$6,$E$2:$E$11,$F7)
    Enter > Copy down
  9. J7
    =COUNTIFS($B$2:$B$11,$F$6,$A$2:$A$11,$I$6,$E$2:$E$11,$F7,$E$2:$E$11,">0")
    Enter > Copy down
sna
Re: External
Post by sna »
Thank you 🙏
