sna
Posts: 721 Joined: Tue May 05, 2020 8:18 am
Excel Ver: Excel 365
by sna » Thu Sep 24, 2020 10:40 am
Hi Dear
How to calculate the difference in hh:mm.
For example I have in cell A2:10:30 ,B2:11
The result would be C2:0:30
I use this
=B2-A2 but no luck
Thanks
Supachok
Posts: 1014 Joined: Wed Jun 18, 2014 11:11 am
Excel Ver: 2013
by Supachok » Thu Sep 24, 2020 11:32 am
Hi sna
=IF(INT(B2),(B2/24),B2)-IF(INT(A2),(A2/24),A2)
Try this formula in cell c2.
sna
by sna » Thu Sep 24, 2020 4:14 pm
This will work but if start is 23:20 and end is 1:30 this not working fine
by snasui » Thu Sep 24, 2020 7:59 pm
sna wrote: Thu Sep 24, 2020 10:40 am
I use this
=B2-A2 but no luck
Try this,
=B2-A2+(B2<A2)
sna
by sna » Fri Sep 25, 2020 5:26 am
It doesn't work
Supachok
Excel Ver: 2013
by Supachok » Fri Sep 25, 2020 9:14 am
This see revise formula as below
the cause of error is time cannot be minus value this formula will be calculate in one day over night is over scope.
=ABS(IF(INT(B2),(B2/24),B2)-IF(INT(A2),(A2/24),A2))
