Public print_list
Public msg
Sub print_selected()
Call OptimizeCode_Begin
Call check_print
tbl_up = ActiveSheet.ListObjects("Input").HeaderRowRange.Row
tbl_low = ActiveSheet.ListObjects("Input").TotalsRowRange.Row
ub = Selection.Rows(1).Row
lb = Selection.Rows.Count + ub - 1
If tbl_up >= ub Or tbl_low <= lb Then
MsgBox "กรุณาเลือก ให้อยู่ในตาราง"
Range("E" & ub & ":" & "E" & lb).Select
Selection.Copy
Range("AR1").Select
Selection.PasteSpecial paste:=xlPasteValues, Operation:=xlNone, SkipBlanks _
:=False, Transpose:=False
Range("AR1").Select
Selection.End(xlDown).Select
sel = ActiveCell.Row
If sel = 1048576 Then
Range("E7").Value = Range("AR1").Value
Call print_s
id_array = Range("AR1:AR" & sel)
For Each id_a In id_array
Sheets("Input").Select
Range("E7").Value = id_a
Call print_s
Next id_a
Columns("AR:AR").Select
Selection.Delete Shift:=xlToLeft
Range("A1").Select
Call OptimizeCode_End
