Printout
sna
Excel Ver: Excel 365
Printout
Post by sna »
Hi Dear,
I got this code from my friend.
Those code is use print from selected any range in a sheet thru inputbox but it is no luck.
Sub PrintIt()
Dim rRange As Range
Set rRange=Application.InputBox("Please select the range",Type:=8)
With Sheets(Application.InputBox("Input Sheet Name"))
.PageSetup.PrintArea=rRange.Address
.PrintOut Copies:=Inputbox("Number of copies:"), Collate:=True
Best wishes
Re: Printout
:D Your code should be show with code style, begin with [code] and end with [/code] like show as below.
Sub PrintIt()
Dim rRange As Range
I have tested this code and it worked properly not show any problem.
sna
Re: Printout
Post by sna »
Hi Dear
This code seems conflict .how do I edit code to
select sheet first then range for printing?
Best wishes
Re: Printout
:D This statement show input box for fill in with your target sheet name for print.
...Other code
Please adjust for your task first and if it has any problem please post here with adjusted code.
