check amount not yet clear
sna
Excel Ver: Excel 365
Post by sna »
Hi Dear
I come up with an issue how to check balance of accrued expense not yet clear.
How can we track them between Debit and Credit Column with the same amount.
I also attached the template
The required result hilighted
Best regards,
Re: check amount not yet clear
:D Sorry, I can't find any logic for matching DR with CR on current data in your file.
sna
Post by sna »
Hi Dear
Thanks for your answer
Best wishes
