Dim iRow As Long
Dim iFormat As String
iRow = Target.Row
If Target.Column = 3 And iRow >= 6 Then 'Column=3 (column C) iRow>=6 (start row)
Select Case Range("C" & iRow)
Case "J": iFormat = "\#,##0;\-#,##0"
Case "T": iFormat = ChrW(3647) & "#,##0.00;-" & ChrW(3647) & "#,##0.00"
End Select
'Range("L" & iRow & ",M" & iRow & ",N" & iRow & ",O" & iRow & ",P" & iRow & ",Q" & iRow).NumberFormatLocal = iFormat
Range("L" & iRow & ":Q" & iRow).NumberFormatLocal = iFormat
Dim iRange As Range
If Not Application.Intersect(Target, Range("C6:C10000")) Is Nothing Then
For Each iRange In Target.Rows
Select Case Range("C" & iRange.Row)
End Select
Range("L" & iRange.Row & ":Q" & iRange.Row).NumberFormatLocal = iFormat
Next
