sumifs not worked with merged cells
sna
Excel Ver: Excel 365
Post by sna »
Hi there!
hope you're all fine
I need your help how use sumifs to work with merge cells without unmerge them
I attach a template
thanks
Re: sumifs not worked with merged cells
:D The example formula in F2 is,
=LET(x,SCAN(A2,A2:A7,LAMBDA(a,b,IF(b="",a,b))),MAP(E2:E3,LAMBDA(y,SUM(FILTER(C2:C7,x=y)))))
sna
Post by sna »
wow,amazing !thanks so much
