sumifs not worked
sna
Excel Ver: Excel 365
sumifs not worked
Post by sna »
hi there,
I have a problem with sumifs ,it is not working .it is wird
i attach a template
thanks
Re: sumifs not worked
:D After checking the result in cell D9, I found that your data did not meet the conditions in the SUMIFS function, particularly at the part 'LN Active-Data'!$AP$5:$AP$163, C9. After filtering your data, only 2 records were found.
Be aware that you can utilize a filter to verify your results when employing SUMIFS.
sna
Post by sna »
Thanks,I filter but not check this column
