calculation issue
sna
Excel Ver: Excel 365
calculation issue
Post by sna »
Hi there,
I needs your help how to calculate interest remaining for loan paid off.
for example i have a loan schedule.
assume client comes to pay off on 07 oct 2022 so amount principal would be as K3 and amount interest would be k4 (sum all left month he/she not yet paid interest).i need to do manual but how can i write formula without manual calculation
is it possible if i type pay off date in J3(Green color cell) it would pop up value in yellow cells say k3 and k4
i attach a template for your reference
tks
Re: calculation issue
:D Please try with these formulas,
K2 =MATCH(MONTH(J3),MONTH(INDEX(RIGHT(B2:B25,10),0)),0)
K3 =OFFSET(H1,K2-1,0)
K4 =SUM(OFFSET(E2,K2,0,12-K2+1))
sna
Post by sna »
it return #N/A .the prone issue ច័ន្ទ 11-07-2022 is from system format as ddd dd-mm-yyyy
:D Please attach file for see and make it easy for members solve this problem.
sna
Post by sna »
tks
Please check the attachment
:D I guess it is up to your regional setting in your machine. In my machine it shows the correct result. Please see the picture below.
sna
Post by sna »
IT set regional setting mm-dd-yy but in this schedule when I right function and extract date it give wrong dd-mm-yy .how to adjust formula without set regional setting because IT department don't allow.
Thanks
:D You can try to change formula on K2 to:
=MATCH(MONTH(J3),INDEX(--MID(RIGHT(B2:B25,10),4,2),0),0)
sna
Post by sna »
Thank you so much .now it is working fine 🙏
