combine 2columns
sna
Excel Ver: Excel 365
combine 2columns
Post by sna »
Hi Dear
I need your help how to check item between lista and listb then combine into a column for matching items.
I attached a
tks
Re: combine 2columns
:D In cell C2 enter this formula,
=IFERROR(INDEX(B:B,AGGREGATE(15,6,ROW($B$2:$B$10)/ISNUMBER(MATCH($B$2:$B$10,$A$2:$A$7,0)),ROWS(C$2:C2))),"")
Enter and copy down.
sna
Post by sna »
Thank you 😊
sna
Post by sna »
Sub test()
Dim i As Long,Lr As Long
Dim rng As Range,C As Range
Dim r
Lr= Sheet1.Range("O" & Rows.Count).End(xlUp).Row
Set rng=Sheet1.Range("O2:O"&Lr)
For Each C in rng.Cells
Set r= Sheet1.Range("U:U").Find(What:=C.Value,Lookin:=xlValues,Look at:=xlWhole)
If Not r is Nothing Then
Range("W" & Rows.Count).End(xlUp).Offset(1).Value = Cells(r.Row,"U")
Next
sna
Post by sna »
Hi Dear
the formula working but I come up with new idea to write code
:D Please attach code in the example file and explain what the problem is.
sna
Post by sna »
Hi Dear,
the code above is aimed to populate data like the formula you gave but no luck.what's wrong?
:D I don't find any error in that code.
sna
Post by sna »
thanks,I will look at it again,may it coz of sheet name
