data populate
sna
Excel Ver: Excel 365
data populate
Post by sna »
Hi dear
I need your help how to populate data in Sheet WHT-HO from sheet Pur-HO column O placing them in highlight cells of sheet WHT-HO.
I also attached a
Thanks
sna
Re: data populate
Post by sna »
here is the attached
Re: data populate
:D Cell A4 on sheet 'Pur-HO' enter this formula:
=IFERROR(INDEX('Pur-HO'!A:A,AGGREGATE(15,6,ROW('Pur-HO'!$A$5:$A$55)/('Pur-HO'!$O$5:$O$55="WHT"),ROWS($A$4:A4))),"")
Enter and copy down. Apply to other column by changing the highlighted character above.
sna
Re: data populate
Post by sna »
thank you
