multiple times base on value
sna
Excel Ver: Excel 365
Post by sna »
Hi Dear,
Good morning, hope you are all doing well.
I need your help how to return multiple times of value base on Next cell .
I can create a helper column and come up with results.
Is there any one way formula to do that without helper?
Thanks
norkaz
Excel Ver: 2013,365
Re: multiple times base on value
Post by norkaz »
G2
=INDEX(B:B,AGGREGATE(15,6,ROW($C$2:$C$4)/(COLUMN($A$2:$Z$2)<=$C$2:$C$4),ROWS($C$2:C2)))&CHAR(ROWS($G$2:G3)-VLOOKUP(ROWS($G$2:G2),A$2:A$4,1)+64)
Norkaz
norkaz
Excel Ver: 2013,365
Post by norkaz »
If no need or without column "A"
G2
=IFERROR(INDEX(B:B,AGGREGATE(15,6,ROW($C$2:$C$4)/(COLUMN($A$2:$Z$2)<=$C$2:$C$4),ROWS($C$2:C2)))&CHAR(ROWS($C$2:C3)-AGGREGATE(15,6,MATCH(ROW($C$2:$C$4),AGGREGATE(15,6,ROW($C$2:$C$4)/(COLUMN($A$2:$Z$2)<=$C$2:$C$4),ROW($C$2:$C$99)-ROW($C$2)+1),0)/((COLUMN($A$2:$Z$2)<=$C$2:$C$4)),ROWS($C$2:C2))+64),"")
Ctrl + Shift + Enter
Norkaz
sna
Post by sna »
Thank you
