extract code by column wise
sna
Excel Ver: Excel 365
Post by sna »
Hi Dear
I need to extract text within brackets to multiple column.
I have listed result starts from column AC.
But the actual result I would need in column B onward.
I add a code below but work only one column
Thanks
Item Code.xlsx
(11.83 KiB) Downloaded 55 times
sna
Re: extract code by column wise
Post by sna »
Sub Extract()
Dim Rng As Range,Dn As Range,Sp As Variant
Set Rng=Range("A2",Range("A"&Rows.Count).End(xlUp))
For Each Dn in Rng
Sp=Split(Dn.Value,"(")
If Ubound(Sp)>0 Then
Dn.offset(,1).Value=Left(Sp(1), Len(Sp(1)) - 1)
End if
Next
:D Please attach file with code inside again for easy to be testing.
sna
Post by sna »
Thanks for your prompt response.
Here's an attachment
Thanks
ect code.xlsm
(17.62 KiB) Downloaded 51 times
:D The example code is below:
Sp = Split(Dn.Value, ")")
If UBound(Sp) > 0 Then
  Dn.Offset(, 1).Value = Mid(Sp(0), 2)
  Dn.Offset(, 2).Value = Sp(1)
sna
Post by sna »
Hi Dear
It works for the first part another no work like in the columns highlight yellow
Thanks
ect code.xlsm
(17.68 KiB) Downloaded 51 times
:D You can adjust code like this:
Set rng = Range("A2", Range("A" & Rows.Count).End(xlUp))
For Each Dn In rng
    For i = LBound(Sp) To UBound(Sp) - 1
       Dn.Offset(0, i + 1).Value = Split(Sp(i), "(")(1)
Next Dn
sna
Post by sna »
Thanks it worked flawlessly
