sna
Posts: 721 Joined: Tue May 05, 2020 8:18 am
Excel Ver: Excel 365
by sna » Thu Dec 17, 2020 3:08 pm
Hi dear,
I need to compare report for BO list and LOS list.
I want to compare Staff code in BO list with LOGIN in LOS list.if it matches return LOGIN, BRANCH_CODE and NAME in REPORT
I also attached a template
Kind regards,
ChoBkuN
Posts: 239 Joined: Tue Nov 29, 2011 3:43 pm
by ChoBkuN » Fri Dec 18, 2020 2:18 pm
Match > Filter > Copy Paste
sna
by sna » Sat Dec 19, 2020 12:15 pm
No.I need formula or vba to compare then extract to REPORT Sheet
Posts: 31262 Joined: Sun Jan 24, 2010 12:33 pm
by snasui » Sun Dec 20, 2020 7:30 am
Try these formulas:
B2
=IFERROR(INDEX('LOS List'!$A$2:$D$1063,AGGREGATE(15,6,MATCH('BO List'!$B$2:$B$102,'LOS List'!$A$2:$A$1063&"",0),ROWS(B$2:B2)),MATCH(B$1,'LOS List'!$A$1:$D$1,0)),"")
Enter > Copy to right and down.
A2
=IF(B2<>"",ROWS(A$2:A2),"")
Enter > Copy down.
sna
by sna » Sun Dec 20, 2020 12:15 pm
Thank you
always work fine
