numerical order
sna
Excel Ver: Excel 365
numerical order
Post by sna »
Hi dear
I want result 1/1... 1/20,2/1...2/20 for the same kode but if different code it should start 1/1 ...1/20,2/1..2/20....etc
B5:B44 it is ok but B45 it should like C45 down...
I also attached file
Re: numerical order
:D The example formula is below:
=MOD(INT((ROWS(B$5:B5)-1)/20),2)+1&"/"&MOD((ROWS(B$5:B5)-1),20)+1
Enter and copy down.
sna
Re: numerical order
Post by sna »
Thanks
