VBA copy files
sna
Excel Ver: Excel 365
VBA copy files
Post by sna »
Hi
Dear
I need your help with copy and paste from folder.I test code is ok but if I copy this file is not working.
I attached working fine and source file
Best Regards,
1. Disbursement Time Analysis 2019-2020.xlsm
(39.13 KiB) Downloaded 62 times
22-09-2020.xlsx
(22.99 KiB) Downloaded 63 times
Re: VBA copy files
:D Could you please capture the error and attach here?
sna
Re: VBA copy files
Post by sna »
Hi Dear,
It doesn't show any error but it doesn't copy the desired output.
I don't know why .I step through the code but nothing occur.
What's wrong with?
Best Regards,
Re: VBA copy files
:D Change MyFile = Path & "*.xls*" to MyFile = Dir(Path & "*.xls*") and if you want to loop other file in this path, add MyFile = Dir() after Application.DisplayAlerts = True statement.
sna
Re: VBA copy files
Post by sna »
Thank you 🙏
sna
Re: VBA copy files
Post by sna »
I try as suggested but no luck.
It has problem copy and paste .it open file but not copy n paste
sna
Re: VBA copy files
Post by sna »
It sometimes can't open file.what is wrong?
excel file is always extension .xlsx
Re: VBA copy files
sna wrote: Mon Sep 28, 2020 5:32 pm excel file is always extension .xlsx
:D It should be '.xlsm'.
