สอบถาม VBA ส่งรูปผ่าน Line notify ครับ
koker12
Post by koker12 »
คือผมติดปัญญาการอ้างอิงรูปภาพครับ ไม่สามารถอ้างอิงได้
Sub SendMessageToLineNotify()
Dim oXML As Object
Dim strToken As String
Dim strMessage As String
Dim strDate As String
Dim URL As String
strToken = Sheet1.Range("B1")
URL = "https://notify-api.line.me/api/notify"
strDate = Format(Now, "DD/MM/YYYY - HH:MM:SS")
Pic = "C:\All\1.jpg"
strMessage = "message=" & strDate & Pic
Set oXML = CreateObject("Microsoft.XMLHTTP")
With oXML
.Open "POST", URL, 0
.SetRequestHeader "Content-Type", "application/x-www-form-urlencoded"
.SetRequestHeader "Authorization", "Bearer " & strToken
.send (strMessage)
Debug.Print oXML.responseText
Set oXML = Nothing
line_test.xlsb
(12.61 KiB) Downloaded 148 times
Re: สอบถาม VBA ส่งรูปผ่าน Line notify ครับ
:D ตัวอย่าง Code การส่งภาพผ่าน Line Notify ตามด้านล่างครับ
Sub SendPictureViaLineNotify()
    Dim URL             As String
    Dim sToken          As String
    Dim sFilepath       As String
    Dim nFile           As Integer
    Dim baBuffer()      As Byte
    Dim ssPostData1     As String
    Dim ssPostData2     As String
    Dim ssPostData3     As String
    Dim Messagelength   As Integer
    Dim arr1()          As Byte
    Dim arr2()          As Byte
    Dim arr3()          As Byte
    Dim arr4()          As Byte
    Dim arraytotal      As Long
    Dim sendarray()     As Byte
    Const STR_BOUNDARY  As String = "------------------------058b4eeb7d99b4f6"
    sToken = "Your token" 'Paste your token after equal sign
    sFilepath = Application.GetOpenFilename(FileFilter:="Picture (*.jpg*),*.jpg*,(*.png*),*.png*")
    If sFilepath = "False" Then Exit Sub
    sfilename = VBA.Right(sFilepath, VBA.InStr(VBA.StrReverse(sFilepath), "\") - 1)
    ssPostData1 = vbCrLf & "--" & STR_BOUNDARY & vbCrLf & _
                   "Content-Disposition: form-data; name=" & """message""" & vbCrLf & vbCrLf
    arr1 = StrConv(ssPostData1, vbFromUnicode)
    arr2 = (" ")
    ssPostData2 = vbCrLf & "--" & STR_BOUNDARY & vbCrLf & "Content-Disposition: form-data; name=" & _
            """imageFile""" & "; filename=" & sfilename & vbCrLf & _
            "Content-Type: image/jpng" & vbCrLf & vbCrLf
    arr3 = StrConv(ssPostData2, vbFromUnicode)
    nFile = FreeFile
    Open sFilepath For Binary Access Read As nFile
    If LOF(nFile) > 0 Then
        ReDim baBuffer(0 To LOF(nFile) - 1) As Byte
        Get nFile, , baBuffer
        imagear = baBuffer
    Close nFile
    arr4 = StrConv(vbCrLf & "--" & STR_BOUNDARY & "--" & vbCrLf, vbFromUnicode)
    arraytotal = UBound(arr1) + UBound(arr2) + UBound(arr3) + UBound(imagear) + UBound(arr4) + 4
    ReDim sendarray(arraytotal)
    For i = 0 To UBound(arr1)
        sendarray(i) = arr1(i)
    Next
    For i = 0 To UBound(arr2)
        sendarray(UBound(arr1) + i + 1) = arr2(i)
    Next
    For i = 0 To UBound(arr3)
        sendarray(UBound(arr1) + UBound(arr2) + i + 2) = arr3(i)
    Next
    For i = 0 To UBound(imagear)
        sendarray(UBound(arr1) + UBound(arr2) + UBound(arr3) + i + 3) = imagear(i)
    Next
    For i = 0 To UBound(arr4)
        sendarray(UBound(arr1) + UBound(arr2) + UBound(arr3) + UBound(imagear) + i + 4) = arr4(i)
    Next
    With CreateObject("Microsoft.XMLHTTP")
        .SetRequestHeader "Content-Type", "multipart/form-data; boundary=" & STR_BOUNDARY
        .SetRequestHeader "Authorization", "Bearer " & sToken
        .send sndar(sendarray)
Public Function sndar(sendarray As Variant) As Byte()
    sndar = sendarray
End Function
ดูเพิ่มเติมที่นี่ครับ Send Image with LINE Notify
koker12
Post by koker12 »
ผมใช้ Code นี้ แล้วมันเป็นแบบนี้ครับ ต้องแก้ไขตรงไหนครับ
:D ตัวแปรนั้นใช้เหมือนต้นฉบับครับ
koker12
Post by koker12 »
ผมอยากให้ ส่งทั้ง รูป และ ตัวหนังสือ ต้องแก้ตรงไหนครับ
:D ใช้ทั้งสอง Code ประกอบกันได้โดยใช้ Code แรกส่งข้อความมและเรียก Code ที่สองเพื่อส่งภาพครับ
koker12
Post by koker12 »
nutpochan
Post by nutpochan »
สอบถามเพิ่มเติม ครับ
ถาม เราจะเอา option หน้าต่าง เลือกไฟล์ ออก
โดย เรากำหนด แหล่งที่อยู่ไฟล์ไป เลย สามารถ แก้ไข โค๊ดได้อย่างไรครับ
nutpochan
Post by nutpochan »
รบกวน เจ้า ของกระทู้ แชร์ โค๊ดที่สำเร็จ ทีครับ
nutpochan wrote: Fri Apr 21, 2023 10:18 pm เราจะเอา option หน้าต่าง เลือกไฟล์ ออก
:D แก้ที่ Statement นี้
ถ้าไม่ต้องการให้เกิด Popup ก็ใส่ Path เข้าไปแทนครับ
nutpochan
Post by nutpochan »
ผม ใส่ เข้าไป แบบนี้ แล้ว eror แก้อย่างไร ครับ
 sFilepath = Application.GetOpenFilename(FileFilter:=C:\Users\nutpo\Desktop\tarket\IMG_9176.JPG)
nutpochan
Post by nutpochan »
 sFilepath = Range("ak2")
แก้ได้ แล้ว ขอบคุณครับ
