Constrain VBA search?
krisney
Post by krisney »
Hello, in your example of MyAdvancedSearch, is there a way to constrain the search to look only at specific columns, rather than the whole range?
Thank you, Kristina
Re: Constrain VBA search?
:D Please attach your example file and point to a column that you want to search.
krisney
Post by krisney »
Hello, I've attached the file. The search box is in B1.
Problem 1: It doesn't seem to launch a search every time though. I have to click in the box and hit the Delete button for all of the data rows to be returned to normal (possibly I've done something wrong).
Problem 2: And for some reason it always includes the first row of data, even if the Search Term is not located in that row.
Problem 3: And if I could search for 3 keywords, that would be awesome :thup:
Problem 4: Constrain the search to only specific Columns?
Thank you for trying to help!
Kristina
ForSNASUI.xlsm
(494.39 KiB) Downloaded 52 times
:D Try this code.
Problem 1: In case of B1 is blank this code don't search anything and show all rows of data.
Problem 2: Because the old code starts with Row 4 instead of Row 3.
Problem 3: With the code below you can search many words separated by a comma (ex. Express, issue, BGP, recovery).
Problem 4: The code below will be searching on column C, you can change to any column by changing this line.
For Each r In .Range("c3", .Range("c" & .Rows.Count).End(xlUp))
Sub MyAdvancedSearch()
    Dim r As Range ', v As String
    Dim s As Variant, i As Integer
    Dim j As Integer
    With Sheets("Data")
        .Range("c2").CurrentRegion.EntireRow.Hidden = False
        If .Range("b1").Value = "" Then Exit Sub
        s = Split(.Range("b1").Value, ",")
            j = 0
            For i = 0 To UBound(s)
                If InStr(1, UCase(r.Value), Application.Trim(UCase(s(i)))) > 0 Then
                    j = j + 1
            If j = 0 Then
                r.EntireRow.Hidden = True
krisney
Post by krisney »
Wow - thank you! I have no idea what this new code means (I was just using yours from YouTube)! I'll have to do some research.
How could I change this line to search more than 1 column, or the whole table?
Thank you VERY much - Kristina
krisney wrote: Tue Nov 20, 2018 3:32 am How could I change this line to search more than 1 column, or the whole table?
:D You can change to the code below:
    Dim r As Range, rln  As Range
    Dim j As Integer, str As Variant
    With Sheets("Data")
        For Each r In .Range("a3", .Range("a" & .Rows.Count).End(xlUp))
            j = 0
            For Each rln In r.Resize(1, 20)
                str = str & rln.Value
            Next
                If InStr(1, UCase(str), Application.Trim(UCase(s(i)))) > 0 Then
                    j = j + 1
            If j = 0 Then
Sorry to let you know about the VBA question. One of the board rules members has to try to change the code from the answer to achieve the goal. If the issue persists or a new problem arises, you can request to solve the problem without restriction.
krisney
Post by krisney »
You are awesome Santipong, thank you!
Kristina
