EXCEL TOOLS
Excel Add-ins ที่พัฒนาโดยคุณสันติพงศ์ ณสุย (MVP Excel 2010-2020) ด้วยภาษา C# เพื่อแก้ไขปัญหาไฟล์ใหญ่ คำนวณนาน ทำงานช้า จัดการข้อมูลต่าง ๆ ที่ทำงานประจำวันได้อย่างสะดวกรวดเร็ว สนใจคลิกไปดูได้ที่นี่ครับ => Excel Tools
[code]
เพื่อให้แตกต่างจากข้อความทั่วไป สะดวกในการอ่านและทดสอบ (คลิกเพื่อดูตัวอย่าง)Code: Select all
Public Sub Upload()
Dim Month As String
Dim Ans, PiNo(100), CelVal As Variant
Dim FirstRow, i, j, k, l As Integer
Month = InputBox("¡ÃسҡÃÍ¡à´×͹", "Input Month (Ex. Jan , Feb, Mar)")
Sheets(Month).Activate
FirstRow = 1
i = 1
k = 100
While k > 0
k = k - 1 'k = 100-1 = 99
i = i + 1 ' i = 1 + 1 = 2
CelVal = Cells(FirstRow + i, 2).Value ' CelVal = Cells(1+2,2).value
If CelVal <> 0 Then ' 410253817 <> 0
' Reset k while have data row
k = 100
j = 0
' Create each PiNo
j = j + 1 ' j = 0+1 = 1
PiNo(j) = "" 'PiNo(1) = ""
For l = 1 To Len(CelVal) 'For l = 1 To 9
If Asc(Mid(CelVal, l, 1)) <> 10 And Asc(Mid(CelVal, l, 1)) <> 32 Then ' if 4<>10 And 4<>40 then
PiNo(j) = PiNo(j) & Mid(CelVal, l, 1) 'PiNo(1) = "" & 4
j = j + 1
Next l
Ans = ""
For l = 1 To j
Ans = Ans & WorksheetFunction.VLookup(Val(PiNo(l)), Worksheets("PI").Range("B:C"), 2, 0)
If l < j Then Ans = Ans & Chr(10)
Next l
Cells(FirstRow + i, 3).Value = Ans
Wend
Public Sub Upload()
Dim Month As String
FirstRow = 1
i = 1
k = 100
While k > 0
If CelVal <> 0 And Len(CelVal) > 7 Then ' 410253817 <> 0
k = 100
j = 0
' Create each PiNo
j = j + 1
PiNo(j) = ""
Next l
Ans = ""
For l = 1 To j
Next l
Wend
Dim rngJanAll As Range, rngJan As Range
Dim janStrAll As Variant, i As Integer
Dim strJoin() As Variant, j As Integer
Dim rngPIAll As Range, rngPI As Range
With Worksheets("Jan")
Set rngJanAll = .Range("b3", .Range("b" & .Rows.Count).End(xlUp))
With Worksheets("PI")
Set rngPIAll = .Range("b3", .Range("b" & .Rows.Count).End(xlUp))
For Each rngJan In rngJanAll
janStrAll = Split(rngJan.Value, " ")
For i = 0 To UBound(janStrAll)
j = 0
For Each rngPI In rngPIAll
If InStr(rngPI, janStrAll(i)) Then
ReDim Preserve strJoin(j)
strJoin(j) = rngPI.Offset(0, 1).Value
j = j + 1
Next rngPI
If IsNumeric(VBA.Left(rngJan, 1)) Then
rngJan.Offset(0, 1).Value = Join(strJoin, vbCrLf)
Next rngJan
