Excel query 2
sna
Excel Ver: Excel 365
Excel query 2
Post by sna »
I have a query 2,required dynamic array to transform data
I attach a template
Thk
Re: Excel query 2
:D Give this a shot,
=HSTACK(
    FILTER(B3:B100,B3:B100<>""),
    DROP(FILTER(C3:C100,C3:C100<>""),1),
    DROP(FILTER(D3:D100,D3:D100<>""),1),
    DROP(FILTER(E3:E100,E3:E100<>""),1)
If you’re dealing with many columns, give this a try,
=LET(a,B3:E11,
    REDUCE(
    FILTER(B3:B11,B3:B11<>""),
    SEQUENCE(COLUMNS(a)-1,1,2),
    LAMBDA(acc,e,
        HSTACK(acc,DROP(FILTER(INDEX(a,0,e),INDEX(a,0,e)<>""),1))
You can change B3:E11 to suit your needs.
sna
Re: Excel query 2
Post by sna »
It both works.thk
