Dim i, j, XX, Row_pivot1, Row_pivot2, Row_picklist As Long
Row_pivot1 = Sheets("ห้ามลบ").Cells(5, 2)
Row_pivot2 = Sheets("ห้ามลบ").Cells(6, 2)
Row_picklist = Sheets("ห้ามลบ").Cells(8, 2)
For i = 1 To Row_picklist
If Sheets("Picklist").Cells(i, 11).Value = "Defective" Or Sheets("Picklist").Cells(i, 11).Value = "Damaged" Then
If Sheets("Picklist").Cells(i, 6).Value <> " " And (Application.WorksheetFunction.Match(Sheets("Picklist").Cells(i, 6).Value, Sheets("Pivot_copy").Range("J:J"), 0)) Then
XX = Application.WorksheetFunction.Match(Sheets("Picklist").Cells(i, 6).Value, Sheets("Pivot_copy").Range("J:J"), 0)
For j = 0 To Row_pivot2
If Application.WorksheetFunction.Index(Sheets("Pivot_copy").Range("J:P"), XX + j, 1) = Sheets("picklist").Cells(i, 6) And Application.WorksheetFunction.Index(Sheets("Pivot_copy").Range("J:P"), XX + j, 6) >= Sheets("picklist").Cells(i, 10) Then
Sheets("picklist").Cells(i, 7).Value = Sheets("Pivot_copy").Cells(XX + j, 16)
Cells(i, 7).Select
Selection.Copy
:=False, Transpose:=False
Exit For
Next j
ElseIf Sheets("Picklist").Cells(i, 11).Value <> "Defective" Or Sheets("Picklist").Cells(i, 11).Value <> "Damaged" Then
If Sheets("Picklist").Cells(i, 6).Value <> " " And (Application.WorksheetFunction.Match(Sheets("Picklist").Cells(i, 6).Value, Sheets("Pivot_copy").Range("A:A"), 0)) Then
XX = Application.WorksheetFunction.Match(Sheets("Picklist").Cells(i, 6).Value, Sheets("Pivot_copy").Range("A:A"), 0)
If Application.WorksheetFunction.Index(Sheets("Pivot_copy").Range("A:G"), XX + j, 1) = Sheets("picklist").Cells(i, 6) And Application.WorksheetFunction.Index(Sheets("Pivot_copy").Range("A:G"), XX + j, 6) >= Sheets("picklist").Cells(i, 10) Then
Sheets("picklist").Cells(i, 7).Value = Sheets("Pivot_copy").Cells(XX + j, 7)
Cells(i, 7).Select
Selection.Copy
Exit For
Next j
ElseIf Sheets("Picklist").Cells(i, 11).Value = "Defective" Or Sheets("Picklist").Cells(i, 11).Value = "Damaged" Then
If Sheets("Picklist").Cells(i, 6).Value <> " " And (Application.WorksheetFunction.Match(Sheets("Picklist").Cells(i, 6).Value, Sheets("Pivot_copy").Range("K:K"), 0)) Then
XX = Application.WorksheetFunction.Match(Sheets("Picklist").Cells(i, 6).Value, Sheets("Pivot_copy").Range("K:K"), 0)
If Application.WorksheetFunction.Index(Sheets("Pivot_copy").Range("K:P"), XX + j, 1) = Sheets("picklist").Cells(i, 6) And Application.WorksheetFunction.Index(Sheets("Pivot_copy").Range("K:P"), XX + j, 5) >= Sheets("picklist").Cells(i, 10) Then
Cells(i, 7).Select
Selection.Copy
Exit For
Next j
If Sheets("Picklist").Cells(i, 6).Value <> " " And (Application.WorksheetFunction.Match(Sheets("Picklist").Cells(i, 6).Value, Sheets("Pivot_copy").Range("B:B"), 0)) Then
XX = Application.WorksheetFunction.Match(Sheets("Picklist").Cells(i, 6).Value, Sheets("Pivot_copy").Range("B:B"), 0)
If Application.WorksheetFunction.Index(Sheets("Pivot_copy").Range("B:G"), XX + j, 1) = Sheets("picklist").Cells(i, 6) And Application.WorksheetFunction.Index(Sheets("Pivot_copy").Range("B:G"), XX + j, 5) >= Sheets("picklist").Cells(i, 10) Then
Cells(i, 7).Select
Selection.Copy
Exit For
Next j
