ReconcileTxn new
sna
Excel Ver: Excel 365
ReconcileTxn new
Post by sna »
Hi Dear
I come again with issue date extract and rate
So Reconcile Txn highlight all cells because date and rate no matching.
Note date in AH and rate in AJ Sheet Intranet
Best wishes
Re: ReconcileTxn new
:D Where is the correct result?
sna
Post by sna »
I want to compare value of items in Sheet Reconcile Txn.the result should be true in column AB otherwise false so if it is false range be highlighted.
Best wishes
sna
Post by sna »
The date and rate no matching.is there any formula to handle this matter?
:D Is this the same subject of viewtopic.php?p=103986#p103986 and why you create a new one?
If the subject is the same, you can continue posting on that subject.
Please point to the row of record that show incorrect data, show me the correct value and how to calculate.
sna
Post by sna »
Hi Dear,
It's the same but I don't want to make it's long.so I create new because the old thread is solved.but now come up with date extract and rate extract.it got a problem because the cells highlight yellow .it means it is no matching.
Best Regards
sna
Post by sna »
In Sheet Intranet
IF(AG6="","",LEFT(S6,9)) this formula to get date from S6
This formula below to extract rate from M6
=IF(M6,LEFT(M6,FIND("%",M6&"%")-1)*IF(M6<0.59,12*100,IF(COUNT(SEARCH({"per year","ក្នុងមួយឆ្នាំ"," ក្នុង1ឆ្នាំ","1year"},M6)),1,12)),"")
It error those part
sna wrote: Sun Oct 18, 2020 10:01 amIt's the same
:D Sorry for inform that you must post in old subject.
sna wrote: Sun Oct 18, 2020 10:12 am In Sheet Intranet
It error those part
I won't transform above formula to your condition. Please explain all condition you use instead.
sna
Post by sna »
Ok I shall post in old
