sharing task
sna
Excel Ver: Excel 365
sharing task
Post by sna »
Hi Dear
Coming back.
I need your help how to calculate duration in minutes between column T and Column S and show result in Column AA.
Once more I need your help how to allocate work load for people in column AD.
I have data 56 transactions for 4 people.I want to allocate those transactions into 14 transactions per each person.the output as in sheet RESULT .
I do this manually every day
Is it possible to do this with Macro????
Best Regards,
Re: sharing task
:D Try this,
Cel AA6
=SUBSTITUTE(T6,"|","")-SUBSTITUTE(S6,"|","")
Enter and copy down > Set number format to h:mm:ss
I can't understand your report and not found macro in your file that related with this task.
sna
Re: sharing task
Post by sna »
I don't know how to create macro for this.I need to generate report to allocate workload for 4 people as listed in Column AD.i mean there're 56 transactions and 4 people so 56/4=14.so each has 14 transactions to complete.if 73 transactions so 73/4=18. The purpose I need to assign transactions to 4 people equally.the output should be like in RESULT Sheet.
Is it possible to do with macro?
Best Regards,
Re: sharing task
sna wrote: Fri Sep 25, 2020 5:35 am I don't know how to create macro for this.
:D The one rule of this forum is you must write code with yourself. If it has any problem, you can ask here.
sna
Re: sharing task
Post by sna »
Ok.thank you very much
