ป้องกันการป้อนข้อมูลซ้ำ ทั้งในSheetตัวเองและSheetถัดไปทุกSheet ใน VBA Excel
Jukkrapong23
Post by Jukkrapong23 »
Sub Duplicate()
    Dim lRow As Long, wsLRow As Long, i As Long
    Dim aCell As Range
    Dim ws As Worksheet, sh As Worksheet
    Dim strSearch As String
    Dim show As Integer
    show = 0
    Set sh = ActiveSheet()
    With sh
        '~~> Get last row in Col A of the sheet
        '~~> which got activated
        'lRow = sh.Range("C6", sh.Range("C6").End(xlDown)).Rows.Count
        lRow = Cells(Rows.Count, "C").End(xlUp).Row
        '~~> Remove existing Color from the column
        '~~> This is to cater for any deletions in the
        '~~> other sheets so that cells can be re-colored
        .Columns(3).Interior.ColorIndex = xlNone
        '~~> Loop through the cells of the sheet which
        '~~> got activated
        For i = 6 To lRow
            '~> Store the ID in a variable
           strSearch = .Range("C" & i).Value
            If strSearch <> "" Then
            '~~> loop through the worksheets in the workbook
            For Each ws In ThisWorkbook.Worksheets
                '~~> This is to ensure that it doesn't
                '~~> search itself
                If ws.Name <> sh.Name Then
                    wsLRow = ws.Range("C" & ws.Rows.Count).End(xlUp).Row
                    '~~> Use .Find to quick check for the duplicate
                    Set aCell = ws.Range("C6:C" & wsLRow).Find(What:=strSearch, _
                                                               LookIn:=xlValues, _
                                                               LookAt:=xlWhole, _
                                                               SearchOrder:=xlByRows, _
                                                               SearchDirection:=xlNext, _
                                                               MatchCase:=False, _
                                                               SearchFormat:=False)
                    '~~> If found then color the cell red and exit the loop
                    '~~> No point searching rest of the sheets
                    If Not aCell Is Nothing Then
                        sh.Range("C" & i).Interior.ColorIndex = 3
                        show = 1
                        Exit For
            Next ws
    Dim lastRow As Long
    Dim matchFoundIndex As Long
    Dim iCntr As Long, iCntr2 As Long
    With sh
    'lastRow = Cells(Rows.Count, "C").End(xlUp).Row
    'lastRow = sh.Range("C6", sh.Range("C6").End(xlDown)).Rows.Count
    'lastRow = .Range("C" & .Rows.Count).End(xlUp).Row
    'lastRow = lRow
    iCntr = 6
    For iCntr = 6 To lRow
    If Cells(iCntr, 6) <> "" Then
        matchFoundIndex = WorksheetFunction.Match(Cells(iCntr, 3), Range("C6:C" & iCntr), 0)
        If iCntr <> matchFoundIndex Then
            Cells(iCntr, 3).Interior.ColorIndex = 3
            show = 1
        If iCntr = matchFoundIndex And iCntr <> lRow Then
            iCntr2 = iCntr + 1
            matchFoundIndex = WorksheetFunction.Match(Cells(iCntr, 3), Range("C" & iCntr2 & ":C" & lRow), 0)
                show = 1
    Next
    If show = 1 Then
        MsgBox ("Duplicate ID Sheet")
(ปัญหาตอนนี้โค้ดของโปรแกรมปัจจุบันสามารถตรวจสอบใน Sheet อื่นๆได้ แล้วก็แจ้งเตือนได้ แต่ไม่สามารถตรวจสอบใน Sheet ตนเอง ถึงแม้เลขจะซ้ำกันก็ตาม)
เป้าหมาย
  • ต้องการตรวจสอบและแจ้งเตือนเมื่อเลขซ้ำกันใน Sheet ตนเอง
  • ต้องการตรวจสอบและแจ้งเตือนเมื่อตรวจสอบกับ Sheet อื่น
Re: ป้องกันการป้อนข้อมูลซ้ำ ทั้งในSheetตัวเองและSheetถัดไปทุกSheet ใน VBA Excel
:D ช่วยแนบไฟล์ตัวอย่างที่มี Code นี้มาด้วยจะได้สะดวกในการทดสอบครับ
Jukkrapong23
ขอโทษทีที่ไม่ได้ตอบครับ พอดีผมแก้ไขได้แล้วครับ
ทีนี้ผมอยากทราบวิธีที่จะ link โค้ด นี้ให้มันตรวจสอบกับอีกไฟล์งานหนึ่ง จะทำได้อย่างไรครับ
Jukkrapong23 wrote: Thu Sep 06, 2018 10:00 pm ขอโทษทีที่ไม่ได้ตอบครับ พอดีผมแก้ไขได้แล้วครับ
:D กรุณาแนบไฟล์ตัวอย่างพร้อม Code และอธิบายรายละเอียดว่าต้องการตรวจสอบกับค่าในไฟล์ไหน ชีตไหน ฯลฯ ครับ
