Sub record()
Dim rs As Range, rt As Range
Dim rc As Range
Worksheets("FormIn").Range("H9") _
= Application.Max(Worksheets("Import") _
.Range("B:B")) + 1
With Worksheets("Template")
i = Application.CountIf( _
.Range("L2:L15"), ">0")
Set rs = .Range("A2:M" & 1 + i)
If Worksheets("FormIn").Range("H17") = "" Then
MsgBox "กรุณาใส่ข้อมูลให้ครบถ้วน"
Set rt = Worksheets("Import") _
.Range("A65536").End(xlUp).Offset(1, 0)
rs.Copy
rt.PasteSpecial xlPasteValues
MsgBox "Finish"
Sub record()
Dim i As Integer, r As Range
Dim rc As Range
.Range("B:B")) + 1
With Worksheets("FormIn")
If .Range("c17").Value = "" Then Exit Sub
For Each r In .Range("c17", .Range("c32").End(xlUp))
If r.Value <> "" And r.Offset(0, 5).Value = "" Then
MsgBox "â»Ã´ÃкػÃÔÁÒ³ã¹à«ÅÅì " & r.Offset(0, 5).Address(0, 0)
rs.Copy
MsgBox "Finish"
