amortisation
sna
Excel Ver: Excel 365
amortisation
Post by sna »
Hi Dear!
I have data in B2:H4 i need to generate allocation of prepaid expense base on amount from start date to end date.I need to generate even amount but only two dicimal so the last amount may be a bit different to adjust sum of the allocation equals to the base amount.
Previously ,I used this formula
=IF((B3<=EOMONTH(--$G$2:$R$2,-1)+1)*(C3>=$G$2:$R$2),ROUND(E3/D3,2),0)
i attached a template
Note I use excel 365
thanks
norkaz
Excel Ver: 2013,365
Re: amortisation
Post by norkaz »
G3
=IF(COLUMNS($G3:G3)=MONTH($C3),$E3-ROUND($E3/$D3,2)*($D3-1),IF(COLUMNS($G3:G3)<MONTH($C3),IF(COLUMNS($G3:G3)<MONTH($B3),"",ROUND($E3/$D3,2)),""))
Copy to the right-hand side and copy down.
Bigcat9
RCA Bangkok Thailand
norkaz
Excel Ver: 2013,365
Re: amortisation
Post by norkaz »
For the spill array formula, you can try this.
G3
=LET(s,SEQUENCE(,12),IF(s=MONTH(C3:C4),E3:E4-ROUND(E3:E4/D3:D4,2)*(D3:D4-1),IF(s<MONTH(C3:C4),IF(s<MONTH(B3:B4),"",ROUND(E3:E4/D3:D4,2)),"")))
Bigcat9
sna
Re: amortisation
Post by sna »
Thx,will take a look
sna
Re: amortisation
Post by sna »
thank you for your nice solution.i come up with a formula =IF(
OR(
MONTH(DATEVALUE(G$2&" 1")) < MONTH($B3),
MONTH(DATEVALUE(G$2&" 1")) > MONTH($C3)
), "-",IF(MONTH(DATEVALUE(G$2&" 1")) = MONTH($C3),
ROUND($E3 - SUM($F3:F3), 2),
ROUND($E3/$D3, 2)
norkaz
Excel Ver: 2013,365
Re: amortisation
Post by norkaz »
sna wrote: Mon Mar 04, 2024 5:45 pm thank you for your nice solution.i come up with a formula =IF(
OR(
ROUND($E3/$D3, 2)
Great! :thup: :thup: :thup:
Bigcat9
sna
Re: amortisation
Post by sna »
Thank you for always help! :thup: :thup: :thup:
