text concatenation
sna
Excel Ver: Excel 365
text concatenation
Post by sna »
Hi there!
I need your expert help to combine the lines in column B at each change in the date in column A, with a formula in Column C.
I attach a sample
Thank you
sna
Re: text concatenation
Post by sna »
I need to concat text until it reaches another date.the expected result in column C
Thank you
norkaz
Excel Ver: 2013,365
Post by norkaz »
Excel 2019
C2
=CONCAT(IF(LOOKUP(ROW($A$2:$A$20),ROW($A$2:$A$20)/($A$2:$A$20<>""))=ROW(A2),$B$2:$B$20&" ",""))
Ctrl + Shift +Enter
or
=TEXTJOIN(" ",1,IF(LOOKUP(ROW($A$2:$A$20),ROW($A$2:$A$20)/($A$2:$A$20<>""))=ROW(A2),$B$2:$B$20,""))
Ctrl + Shift +Enter
Norkaz
sna
Post by sna »
Thank you it is working
