cal.fifo
sna
Excel Ver: Excel 365
cal.fifo
Post by sna »
Hi dear,
I need your input how to calculate FiFo in excel using formula .I attach a sample with output in color cells and how to calculate amount in the next column as well.
Thanks
norkaz
Excel Ver: 2013,365
Re: cal.fifo
Post by norkaz »
Hi Guy
Not sure what the point is that you need to fill out.
Try the results as attached, if it's not suited to your question, please give more clarification somehow to get that.
F2
=SUMPRODUCT((A2=$K$6:$K$21)*$L$6:$L$21)
H2
=SUMPRODUCT((A2=$K$6:$K$21)*$L$6:$L$21*$M$6:$M$21)
Norkaz
sna
Re: cal.fifo
Post by sna »
Thanks but the date in SALES!A:A not $K$6:$K$21
norkaz
Excel Ver: 2013,365
Re: cal.fifo
Post by norkaz »
Refer to your attachment, if the date in SALES!A:A, it's quite not possible to get the results that I provided.
Please give more clarification If I've missed out on something that would be useful to you.
Norkaz
sna
Re: cal.fifo
Post by sna »
FIFO method is calculate for First On First Out,it means goods purchased first Sold out first
norkaz
Excel Ver: 2013,365
Re: cal.fifo
Post by norkaz »
I know the FIFO method but I would like to know more if my answers matched your requirement or not.
If yes, it would be great.
If not, please explain why not, give more sample answers as it would be.
Norkaz
sna
Re: cal.fifo
Post by sna »
your answer is correct but I don't need helper column in K column.is it possible?
norkaz
Excel Ver: 2013,365
Re: cal.fifo
Post by norkaz »
As the FIFO method, It's quite not possible if don't have the "Exactly Date" referring Sales Qty. in L:L that matches the date in A:A.
Norkaz
Bo_ry
Excel Ver: MS 365
Re: cal.fifo
Post by Bo_ry »
Try
F2
=MIN(C2,SUMIFS(SALES!$C$2:$C$25,SALES!$B$2:$B$25,$B2)-SUMIFS(F$1:F1,B$1:B1,B2))
H2
=SUM(TEXT(IF(SUMIFS(F$2:F2,B$2:B2,B2)-MMULT(--(ROW(SALES!$B$2:$B$25)>TRANSPOSE(ROW(SALES!$B$2:$B$25))),SALES!$C$2:$C$25*(SALES!$B$2:$B$25=B2))<SALES!$C$2:$C$25,SUMIFS(F$2:F2,B$2:B2,B2)-MMULT(--(ROW(SALES!$B$2:$B$25)>TRANSPOSE(ROW(SALES!$B$2:$B$25))),SALES!$C$2:$C$25*(SALES!$B$2:$B$25=B2)),SALES!$C$2:$C$25),"0;\0")*SALES!$D$2:$D$25*(SALES!$B$2:$B$25=B2))-SUMIFS(H$1:H1,B$1:B1,B2)
Ctrl+Shift+Enter
sna
Re: cal.fifo
Post by sna »
Thank bo_ry
