sna
Posts: 721 Joined: Tue May 05, 2020 8:18 am
Excel Ver: Excel 365
by sna » Mon Nov 22, 2021 7:09 pm
Hi Dear,
I need your help how to get the results as in column B.i used the weeknum function but it is no luck.
I also attached a sample
Thank
norkaz
Posts: 1829 Joined: Wed Jan 12, 2011 7:59 pm
Excel Ver: 2013,365
by norkaz » Mon Nov 22, 2021 7:49 pm
B2
=INT(ROWS(B$2:B7)/6)
Norkaz
sna
by sna » Tue Nov 23, 2021 9:39 am
thank you but another choice could it work with weeknum function?
norkaz
Excel Ver: 2013,365
by norkaz » Tue Nov 23, 2021 10:33 am
Hi Guy
As far as we know the weeknum function returns the number of each week.
Refer to your data that shows 6 days per week and skips the Sundays. If your data pattern is always like that, the formula at B2 should be...
B2
=WEEKNUM(A2)-WEEKNUM($A$2)+1
Norkaz
sna
by sna » Tue Nov 23, 2021 11:45 am
Thank you
