Master Calendar
sna
Excel Ver: Excel 365
Master Calendar
Post by sna »
Hi Dear,
I need your help regarding leave tracking.
I got a file from my friend.
He needs to list down day base on Drop down list Selection : Monday or Sunday and year 2021 as well as by January, February....
he needs to track his subordinate leave.
Thanks
Re: Master Calendar
Creat New RangeName DaysAndWeeks2=ROW(B5:B46)-ROW(B5)
Select B5:B46 Put =DaysAndWeeks2+DATE($B$1,1,1)-WEEKDAY(DATE($B$1,1,1),($B$2="Monday")+1)+1 Press Ctrl+Shift+Enter
A5=LEFT(TEXT(B5,"[$-en]ddd,"),1)
A4=B5
sna
Re: Master Calendar
Post by sna »
Thank but I need to start from beginning of year 2021 not Dec 2019
Thank
sna
Re: Master Calendar
Post by sna »
Hi Dear could you give formula to start from 1 Jan 21 to Dec 21 base on year and month and week start?
Thanks
Re: Master Calendar
:D Please attach the latest file, point to the problem and explain what is the correct result.
sna
Re: Master Calendar
Post by sna »
Here is an updated file with expected Result
Thank you
Re: Master Calendar
Sample Formula B5=IF(N(B4),MAX(B4:B$5)+1,DATE(B$1,COUNTIF(B$4:B4,"Day"),1))
sna
Re: Master Calendar
Post by sna »
Thank you 🙏
