list visible
sna
Excel Ver: Excel 365
list visible
Post by sna »
Hi Dear
I have a problem with macro to list all visible sheets.
Here's a code from my friend
Sub test()
Dim i As integer
Dim sh As Worksheet
Sheets.add after:=Sheets(Sheets.count)
For Each sh in ThisWorkbook.Worksheets
i=i+1
If sh.Visible=xlSheetVisible Then
Cells(i,1).Value=sh.Name
End if
Next
But it is no luck, what is going wrong?
Best wishes,
Re: list visible
:D Please post your code in the form of 'code style' and attach the example file for easy to test.
sna
Re: list visible
Post by sna »
Dear ,,
How can I post code in form of 'Code style'?
Best regards
Re: list visible
sna
Re: list visible
Post by sna »
Sub test()
Dim i As integer
Dim sh As Worksheet
i=i+1
End if
Next
Re: list visible
:D You can use this code for listing all visible sheets.
Dim i As Integer, sh As Worksheet
For Each sh In ThisWorkbook.Worksheets
    If sh.Visible = xlSheetVisible Then
        i = i + 1
        Cells(i, 1).Value = sh.Name
Next
