rent calculation
sna
Excel Ver: Excel 365
rent calculation
Post by sna »
Dear All,
I have the following criteria
Criteria Rental Oil Repair
Currently 18 11 15
1 year before currently 14 10 15
2 year before currently 13 10 15
3 year before currently 11 7 15
4 year before currently 10 5 15
I need to calculate rental,oil and repair for Motor plate no. 1K9856 Series Year 2018?
The result would be Rental 13,Oil 10 and repair 15.
I don't need a helper column?
Is there any formula?
Best regards,
Re: rent calculation
:D On C3 should be
=INDEX(B7:B11,YEAR(TODAY())-$B3+1)
Press enter and adapt the highlighted part of formula above for use with E3 and F3.
sna
Post by sna »
Hi Dear
Thanks it works well 🙏
Is it possible to use Choose?
Best wishes,
:D Yes, you can do it with 'Choose'.
For example on C3
=CHOOSE(YEAR(TODAY())-B3+1,B7,B8,B9,B10,B11)
sna
Post by sna »
Thanks again
Best wishes,
