ListBox
sna
Excel Ver: Excel 365
ListBox
Post by sna »
Hi Dear All,
I need to ask you VBA expert.
how can we select the columns then those columns will populate on ListBox.
I mean use mouse selecting those columns
I attached the template
Thanks
Re: ListBox
:D Sorry for inform you about VBA question, one of the rule of this forum is needed some code from yourself that try to solve this problem and have that code inside your example file.
sna
Re: ListBox
Post by sna »
Hi Dear
I have attached file with code inside
sna
Re: ListBox
Post by sna »
I also attached sample file with macro
Re: ListBox
:D Please check your attached file again. I have not found any piece of code.
sna
Re: ListBox
Post by sna »
I need your help to select non contiguous columns with or without inputbox
sna
Re: ListBox
Post by sna »
Here is the code
Re: ListBox
:D The example code is below:
Private Sub UserForm_Activate()
    'On Error Resume Next
    Dim rRange As Range, rList As Range, strRowSource As String
    Set rRange = Application.InputBox(Prompt:="Please Select Range", _
        Title:="Range Select", Type:=8)
    With Sheets("Sheet1")
        If .Range("l2") <> "" Then .Range("l2").CurrentRegion.ClearContents
        rRange.Copy .Range("l2")
        Set rList = .Range("l2").CurrentRegion
        strRowSource = .Name & "!" & rList.Address(0, 0)
        Me.ListBox1.RowSource = strRowSource
sna
Re: ListBox
Post by sna »
Thanks
