Tudtoo
Posts: 8 Joined: Tue Apr 24, 2018 10:55 am
by Tudtoo » Tue Apr 24, 2018 11:06 am
ต้องการแก้ไข macro ที่ใช้ Pivot Table ในกรณีที่ข้อมูลที่ใช้มีการเพิ่มแถวหรือคอลัมน์
"ตัวอย่างโค้ดที่ได้จากการบันทึก macro ครั้งแรก"
Range("A1").Select
Sheets("Sheet1").Select
Sheets("Sheet1").Name = "ใบเจน PO."
Sheets.Add
ActiveWorkbook.PivotCaches.Create(SourceType:=xlDatabase, SourceData:= _
"ใบเจน PO.!R1C1:R841C25", Version:=6).CreatePivotTable TableDestination:= _
"Sheet2!R3C1", TableName:="PivotTable1", DefaultVersion:=6
Sheets("Sheet2").Select
Cells(3, 1).Select
With ActiveSheet.PivotTables("PivotTable1")
.ColumnGrand = True
.HasAutoFormat = True
.DisplayErrorString = False
.DisplayNullString = True
.EnableDrilldown = True
.ErrorString = ""
.MergeLabels = False
.NullString = ""
.PageFieldOrder = 2
.PageFieldWrapCount = 0
.PreserveFormatting = True
.RowGrand = True
.SaveData = True
.PrintTitles = False
.RepeatItemsOnEachPrintedPage = True
.TotalsAnnotation = False
.CompactRowIndent = 1
.InGridDropZones = False
.DisplayFieldCaptions = True
.DisplayMemberPropertyTooltips = False
.DisplayContextTooltips = True
.ShowDrillIndicators = True
.PrintDrillIndicators = False
.AllowMultipleFilters = False
.SortUsingCustomLists = True
.FieldListSortAscending = False
.ShowValuesRow = False
.CalculatedMembersInFilters = False
.RowAxisLayout xlCompactRow
With ActiveSheet.PivotTables("PivotTable1").PivotCache
.RefreshOnFileOpen = False
.MissingItemsLimit = xlMissingItemsDefault
ActiveSheet.PivotTables("PivotTable1").RepeatAllLabels xlRepeatLabels
With ActiveSheet.PivotTables("PivotTable1").PivotFields("Article")
.Orientation = xlRowField
.Position = 1
ActiveSheet.PivotTables("PivotTable1").AddDataField ActiveSheet.PivotTables( _
"PivotTable1").PivotFields("Quantity in SKU"), "Sum of Quantity in SKU", xlSum
"PivotTable1").PivotFields("Order Quantity"), "Sum of Order Quantity", xlSum
"PivotTable1").PivotFields("Net Order Value"), "Sum of Net Order Value", xlSum
Sheets("Sheet2").Name = "SUM PO.เจน"
by logic » Tue Apr 24, 2018 2:45 pm
ทำไฟล์ตัวอย่างแนบมาด้วยจะได้ช่วยกันดูครับ
Tudtoo
by Tudtoo » Tue Apr 24, 2018 3:06 pm
จากไฟล์ตัวอย่างต้องการ Pivot ข้อมูลในช่อง M และ S ซึ่งในแต่ละวันจำนวน row จะไม่เท่ากันทำให้ pivot ข้อมูลมาไม่ครบทั้งหมด
ใบเจน Po..XLSX
(179.85 KiB) Downloaded 51 times
by snasui » Tue Apr 24, 2018 7:10 pm
ไฟล์ที่แนบคือไฟล์ที่เขี่ยน Code เอาไว้แล้ว จะต้องมีนามสกุลเป็น .xlsm เป็นอย่างน้อยไม่ใช่นามสกุลเป็น .xlsx ช่วยแนบมาใหม่อีกรอบครับ
Tudtoo
by Tudtoo » Wed Apr 25, 2018 3:18 pm
แก้ไขไฟล์แนบให้ใหม่แล้วค่ะ ขอบคุณค่ะ
by snasui » Wed Apr 25, 2018 8:06 pm
ตัวอย่างการปรับ Code ครับ
'Other code...
Dim data As Range
With ActiveSheet
Set data = .UsedRange
Sheets.Add
data, Version:=6).CreatePivotTable TableDestination:= _
"Sheet3!R3C1", TableName:="PivotTable1", DefaultVersion:=6
'Other code...
