Sub MotherLotSelected()
Dim lngLastRow As Long
Worksheets("Sampled").Select
Range("B1").Select
Selection.Copy
If DoesWorkSheetExist("Mother_Lot_Sampled") = False Then 'If "Temp" sheet not there, create it.
Worksheets.Add().Name = "Mother_Lot_Sampled"
Worksheets("Mother_Lot_Sampled").Select
ActiveSheet.Tab.ColorIndex = xlColorIndexNone ' Remove tab color
Range("A1").Select
ActiveSheet.Paste
Range("B1").Select
ActiveCell.FormulaR1C1 = "MOTHERLOT"
Range("B2").Select
ActiveCell.Formula = "=LEFT(A2,13)"
lngLastRow = Cells(Rows.Count, "A").End(xlUp).Row
'Range("B2").AutoFill Destination:=Range("B2:B" & lngLastRow)
ActiveSheet.Move After:=ActiveWorkbook.Sheets("Load")
Sub GroupAssignment()
Dim lngLastRowSource As Long
Dim strLastRowSource As String
Dim strFormulaText As String
Worksheets("Load").Select
Range("H1").Select
ActiveCell.Formula = "MOTHERLOT"
Range("H2").Select
ActiveCell.Formula = "=LEFT(B2,13)"
Range("H2").AutoFill Destination:=Range("H2:H" & lngLastRow)
lngLastRowSource = Sheets("Mother_Lot_Sampled").Cells(Rows.Count, "A").End(xlUp).Row
Range("H1:H" & lngLastRow).AdvancedFilter Action:=xlFilterInPlace, CriteriaRange:= _
Sheets("Mother_Lot_Sampled").Range("B1:B" & lngLastRowSource), Unique:=False
Rows("2:2").Select
Selection.Delete Shift:=xlUp
ActiveSheet.ShowAllData
Range("C1").Select
ActiveCell.Formula = "AA"
Range("D1").Select
ActiveCell.Formula = "BB"
Range("E1").Select
ActiveCell.Formula = "CC"
Range("F1").Select
ActiveCell.Formula = "DD"
Range("G1").Select
ActiveCell.Formula = "EE"
Sheets("Data").Select
lngLastRowSource = ActiveSheet.Cells(Rows.Count, "A").End(xlUp).Row ' Get the last Target
strLastRowSource = "$B$2:$N$" & CStr(lngLastRowSource)
Range("C2").Select
ActiveCell.Formula = _
"=IF(ISNA(VLOOKUP(A2,'Data'!" + strLastRowSource + ",2,FALSE)),""N/A"",VLOOKUP(A2,'Data'!" + strLastRowSource + ",2,FALSE))"
Range("D2").Select
"=IF(ISNA(VLOOKUP(A2,'Data'!" + strLastRowSource + ",3,FALSE)),""N/A"",VLOOKUP(A2,'Data'!" + strLastRowSource + ",3,FALSE))"
Range("E2").Select
"=IF(ISNA(VLOOKUP(A2,'Data'!" + strLastRowSource + ",4,FALSE)),""N/A"",VLOOKUP(A2,'Data'!" + strLastRowSource + ",4,FALSE))"
Range("F2").Select
"=IF(ISNA(VLOOKUP(A2,'Data'!" + strLastRowSource + ",5,FALSE)),""N/A"",VLOOKUP(A2,'Data'!" + strLastRowSource + ",5,FALSE))"
Range("G2").Select
"=IF(ISNA(VLOOKUP(A2,'Data'!" + strLastRowSource + ",6,FALSE)),""N/A"",VLOOKUP(A2,'Data'!" + strLastRowSource + ",6,FALSE))"
Range("C2:G2").Select
Selection.AutoFill Destination:=Range("C2:G" & lngLastRow)
Public Function DoesWorkSheetExist(WorkSheetName As String, Optional WorkBookName As String)
Dim WS As Worksheet
If WorkBookName = vbNullString Then
Set WS = Sheets(WorkSheetName)
Set WS = Workbooks(WorkBookName).Sheets(WorkSheetName)
On Error GoTo 0
DoesWorkSheetExist = Not WS Is Nothing
End Function
Sub Main()
Const strHandledSheet As String = "Load"
On Error GoTo ErrorHandling
Worksheets(strHandledSheet).Select
MotherLotSelected
GroupAssignment
ErrorHandling:
MsgBox ("No >> ") & strHandledSheet & ("<< sheet available")
