VBA lookup
piches
VBA lookup
Post by piches »
สวัสดีอาจารย์และเพื่อนสมาชิกทุกท่านครับ ช่วยชี้แนะด้วยครับว่าต้องแก้ไขยังไง
Sub TestVBA()
    OptimizeVBA True
    Dim startTime As Single, endTime As Single
    startTime = Timer
    Dim invoice As Range, names As Range, Amount As Range
    Dim lookupInvoice As Range, lookupNames As Range, lookupAmount As Range
    Dim vlookupCol As Object
    Set invoice = Worksheets("Sheet2").Range("A2:A199")
    Set names = Worksheets("Sheet2").Range("B2:B199")
    Set Amount = Worksheets("Sheet2").Range("C2:C199")
    Set lookupInvoice = Worksheets("Sheet1").Range("A2:A12")
    Set lookupNames = Worksheets("Sheet1").Range("B2:B12")
    Set lookupAmount = Worksheets("Sheet1").Range("C2:C12")
    'Build Collection
    Set vlookupCol =[color=#FF0000] BuildLookupCollection(invoice[/color], names, Amount)
    'Lookup the values
    VLookupValues lookupInvoice, lookupNames, lookupAmount, vlookupCol
    endTime = Timer
    Debug.Print (endTime - startTime) & " seconds have passed [VBA]"
    OptimizeVBA False
    Set vlookupCol = Nothing
Function BuildLookupCollection(categories As Range, values As Range)
    Dim vlookupCol As Object, i As Long
    Set vlookupCol = CreateObject("Scripting.Dictionary")
    For i = 1 To categories.Rows.Count
        Call vlookupCol.Add(CStr(categories(i)), values(i))
    Set BuildLookupCollection = vlookupCol
End Function
Sub VLookupValues(lookupCategory As Range, lookupValues As Range, vlookupCol As Object)
    Dim i As Long, resArr() As Variant
    ReDim resArr(lookupCategory.Rows.Count, 1)
    For i = 1 To lookupCategory.Rows.Count
        resArr(i - 1, 0) = vlookupCol.Item(CStr(lookupCategory(i)))
    lookupValues = resArr
Sub OptimizeVBA(isOn As Boolean)
    Application.Calculation = IIf(isOn, xlCalculationManual, xlCalculationAutomatic)
    Application.EnableEvents = Not (isOn)
    Application.ScreenUpdating = Not (isOn)
    ActiveSheet.DisplayPageBreaks = Not (isOn)
Test Lookup.xlsm
(28.39 KiB) Downloaded 109 times
Re: VBA lookup
:D ช่วยเล่าสิ่งที่เป็นปัญหา และแจ้งคำตอบที่ต้องการมาในกระทู้ด้วยครับ
piches
Re: VBA lookup
Post by piches »
Set vlookupCol = BuildLookupCollection(invoice, names, Amount)ต้องแก้ไขเพิ่มเติมตรงไหนครับ
http://analystcave.com/excel-vlookup-vs ... rformance/ผมดูจากเว็ปนี้ครับแต่ไม่เข้าใจตรงนี้ครับ Set vlookupCol = BuildLookupCollection ว่ามีความหมายว่าอย่างไรครับอาจารย์
19-01-2017 21-14-53.png (47.12 KiB) Viewed 1196 times
Re: VBA lookup
:D BuildLookupCollection คือ Function ที่ต้องส่งตัวแปรอีก 2 ตัวไปให้มันจัดการต่อ คือ categories และ values แต่จากภาพที่แนบมานั้น ผมสังเกต Error มองเห็นลาง ๆ ว่าส่งตัวแปรไปเกินกว่าจำเป็น ยกตัวอย่างเช่น ต้องการ 2 ตามด้านบน แต่ส่งไป 3 ตัว คือ invoice, name และ amout จึงฟ้องว่าส่งตัวแปรไปไม่ถูกต้องครับ
piches
Re: VBA lookup
Post by piches »
ขอบคุณครับอาจารย์ ด้วยสมองอันน้อยนิดของผมคงอยากเกินไป มีหลายช่วงที่ไม่เข้าใจถึงความสัมพันธ์ระว่าง subและFunctionทั้ง4ช่วง
อยากสอบถามอาจารย์ว่า หากต้องการเพิ่มช่วงต้องปรับส่วนใดบ้างครับ
ขออนุญาติวาง Code เป็นข้อความนะครับ font สีแดงคือ Codeที่ผมปรับเพิ่มเติมจากเดิม ผมต้องการจะเพิ่มช่วงคนหาจากเดิม 2 ช่วง เป็น 3 ช่วง คือ collumn c ส่วน font สีน้ำเงิน ผมไมรู้จ่าจะปรับยังไงครับ
Sub TestVBA()
OptimizeVBA True
startTime = Timer
'Build Collection
'Lookup the values
endTime = Timer
OptimizeVBA False
ต้องเพิ่มตัวแปลในFunctionอย่างไรครับ
End Function
Re: VBA lookup
:D ตัวอย่างการใส่ Arguments ของ Function และ Procedure ให้สอดคล้องกับการส่งค่าเข้าไปให้ตามด้านล่างครับ
Function BuildLookupCollection(categories As Range, values As Range, amt As Range)
End Function
Sub VLookupValues(lookupCategory As Range, lookupValues As Range, amt As Range, vlookupCol As Object)
