ตัวอย่างก่อนตัดครับ
"<span style='font-size:14px;'><strong>WLtoys V931 2.4G 6CH Brushless AS350 Scale Flybarless RC Helicopter BNF</strong> </span><span style='font-size:14px;'><strong>Blue</strong></span><br />
<br />
<strong><iframe allowfullscreen='' frameborder='0' height='360' src='//
www.youtube.com/embed/ZO_lANMCK4A' width='640'></iframe><br />
<br />
<img alt='' src='
http://imgmgr.banggood.com/images/2014/ ... V931AS.jpg' /><img alt='' src='
http://imgmgr.banggood.com/images/2014/ ... V931AW.jpg' style='width: 790px; height: 5851px;' /><img alt='' src='
http://imgmgr.banggood.com/images/2014/ ... V931QE.jpg' style='width: 790px; height: 13895px;' /><br />
<br />
Description:</strong><br />
<br />
Rotor Diameter: 244 mm<br />
Body Length: 238 mm<br />
Height: 77mm<br />
Battery: 3.7V 500mAh 25C<br />
Flight time: About 5 minutes<br />
Main Motor: Brushless 1106 11000KV<br />
Tail Motor: Brushed 8502<br />
Color:Blue white<br />
<br />
<strong>Features:</strong><br />
<br />
1.According to AS350 (the little squirrel) prototype ratio, high simulation, fine appearance design.The details of the products, unique in the market three rotor blades flybarless design.<br />
2.Quote aerodynamic blade provides strong power and body self stability.<br />
3.1106 rotor brushless motor power is stronger, the 3.7V 500mah 25C high rate battery<br />
4.3D mode using 3 axis gyro, sensitive reaction. To do the stunt flying, can easily make rolling inverted pendulum movement<br />
5.6G mode using 6 axis gyro, flight stability, especially suitable for beginners to flight.<br />
6.6 channel remote control, a 3D special IDLE switch throttle hold TH.HOLD switch large screen liquid crystal display, low voltage alarm function. Especially with aircraft hovering point setting, enter the setting mode to set the hover plane according to their needs.<br />
7.With a dedicated USB charger, can also charge 2 batteries.<br />
<br />
v931 Russian manual <a href='
http://imgmgr.banggood.com/images/uploa ... zip'><span style='color:#ff0000;'>Click here</span></a><br />
v931 English manual <a href='
http://imgmgr.banggood.com/images/upload/2014/02/v931 English.zip'><span style='color:#ff0000;'>Click here</span></a><br />
<br />
<strong>Package Includes:</strong><br />
<br />
1 x WLtoys V931 RC Helicopter BNF(Body Only)<br />
<span style=' line-height: 18px;'>1 x Charger</span><br style='color: rgb(101, 109, 120); font-family: Arial; line-height: 18px;' />
<span style=' line-height: 18px;'>1 x Battery</span><br style='color: rgb(101, 109, 120); font-family: Arial; line-height: 18px;' />
<span style=' line-height: 18px;'>3 x Main Blade</span><br style='color: rgb(101, 109, 120); font-family: Arial; line-height: 18px;' />
<span style=' line-height: 18px;'>1 x Manual</span>"
ตัวอย่างตัดแล้วที่จะไปไปใช้งานครับ
<br />
<br />
Height: 77mm<br />
<br />
<br />
<br />
<br />
