Hi, all
Thank you for your response ChoBkuN that's very helpfull, I'm glad to c the answer for resolve this
but, i just need to improve that, how can i the fastest way to calculation this millage like:
Example : when i type data in sheet IT760 (166336 to 166366= 30 km this cost for user xxx xxx xxxxxx)
everything link automatically and all IT Grant total every sheet must be summaries @ sheet SUMMARY NO(Kilometer).
เวลาทีเราคียจช้มูนใส ให้ทุกอย่างมัน link ไปเอง หลือ จะมี Macro ที่ทำหน้าที่ทุกอย่างเลีย
I want to try answering before Sen' Se'.
In my oppinion.
1. You have to design every sheet as the same table. That it will easy to write formular to summary product from all sheet.
2. And have to delete "Grand total" Column to prevent from summary same product double time. Or move it to another column that's not the same of your data.
3. In this case, I advice you to use "Sumproduct" function to solve this problem krub.
4. Another thing is Rewrite your Refference column to be form as the name sheet. (IT 116 to IT116 "Delete Space")
If you see the attach file below. I have changed somthing in table for easy to write the formular.
For more easier to use. You can redesign it as you want. But don't write any thing as the same of your sheet data. That'll be inturruped the formular.
Delete column "A" on sheet IT116 for shift your data to the same column of other sheets.
Sheet "SUMMARY NO(Kilometre)." cell I4 enter this formula.
=LOOKUP(9.99999999999999E+307,CHOOSE({1,2},0,IF($A4<>"",LOOKUP(2,1/($A4=INDIRECT("'"&SUBSTITUTE(I$3," ","")&"'!A4:A110")),INDIRECT("'"&SUBSTITUTE(I$3," ","")&"'!I4:I110")))))
Enter > Copy across then down.
If you clear space in all fields in "I3:Q3" on sheet "SUMMARY NO(Kilometre)." the formula above can replace with this formula.
Sub Get_Data()
Dim rSource As Variant
Dim rTarget As Range
Sheets("SUMMARY NO(Kilometre).").Range("A70:I" & Rows.Count).Clear
Sheets("SUMMARY NO(Kilometre).").Range("A70") = "Start"
rSource = Array(Sheets("IT116").Range("K7:R25"), _
Sheets("IT760").Range("A54:I71"), _
Sheets("IT134").Range("A47:I63"), _
Sheets("IT1272").Range("A50:I69"), _
Sheets("IT1500").Range("A51:I75"), _
Sheets("IT443").Range("A46:I58"), _
Sheets("IT835").Range("A44:I56"), _
Sheets("IT135").Range("A44:I55"), _
Sheets("IT148").Range("A30:I33"))
For i = 0 To UBound(rSource)
Set rTarget = Sheets("SUMMARY NO(Kilometre).").Range("A" & Rows.Count) _
.End(xlUp).Offset(1, 0)
rSource(i).Copy rTarget
Sub RemoveDup()
Dim r As Range
Dim iCount As Integer
With Sheets("SUMMARY NO(Kilometre).")
Set r = .Range("A71")
i = .Range("A" & Rows.Count).End(xlUp).Row
iCount = 1
Do While iCount <= i
If Application.CountIf(r.Resize(iCount) _
, r(iCount)) > 1 Then
r(iCount).EntireRow.Delete
iCount = iCount + 1
