Sub Save()
Sheets("ทำรายการ").Range("B3").Copy
With Sheets("Save")
.Range("A" & .Range("A" & Rows.Count).End(xlUp).Row).Offset(1, 0).PasteSpecial xlPasteValues
Sheets("ทำรายการ").Range("B5").Copy
With Sheets("Save")
.Range("B" & .Range("B" & Rows.Count).End(xlUp).Row).Offset(1, 0).PasteSpecial xlPasteValues
Sheets("ทำรายการ").Range("B4").Copy
With Sheets("Save")
.Range("D" & .Range("D" & Rows.Count).End(xlUp).Row).Offset(1, 0).PasteSpecial xlPasteValues
Sheets("ทำรายการ").Range("C2").Copy
With Sheets("Save")
.Range("C" & .Range("C" & Rows.Count).End(xlUp).Row).Offset(1, 0).PasteSpecial xlPasteValues
Range("B3").Select
ActiveWorkbook.Save
ทำให้สั้นลงกว่านี้ได้มั้ยครับ ขอบคุณครับ
Sub Save()
Dim wsSource As Worksheet
Dim wsTarget As Worksheet
Dim sourceRange As Variant
Dim targetColumns As Variant
Set wsSource = Sheets("ทำรายการ")
Set wsTarget = Sheets("Save")
sourceRange = Array("B3", "B5", "B4", "C2")
targetColumns = Array("A", "B", "D", "C")
For i = LBound(sourceRange) To UBound(sourceRange)
wsSource.Range(sourceRange(i)).Copy
wsTarget.Range(targetColumns(i) & wsTarget.Cells(Rows.Count, targetColumns(i)).End(xlUp).Row + 1).PasteSpecial xlPasteValues
wsSource.Range("B3").Select
ActiveWorkbook.Save
