Sub MergeColumnsInAB()
Dim wsAB As Worksheet
Dim wsAA As Worksheet
Dim lastColumnAA As Long
Dim colStart As Long
Dim colEnd As Long
Dim i As Long
Set wsAB = ThisWorkbook.Sheets("AB")
Set wsAA = ThisWorkbook.Sheets("AA")
lastColumnAA = wsAA.Cells(1, wsAA.Columns.Count).End(xlToLeft).Column
colStart = 2
colEnd = 5
For i = colStart To lastColumnAA Step 4
If colEnd > wsAB.Columns.Count Then colEnd = wsAB.Columns.Count
With wsAB.Range(wsAB.Cells(2, colStart), wsAB.Cells(2, colEnd))
.Merge
.HorizontalAlignment = xlCenter
.VerticalAlignment = xlCenter
colStart = colStart + 4
colEnd = colEnd + 4
Dim colEnd As Long
Dim i As Long
lastColumnAA = wsAA.Cells(1, wsAA.Columns.Count).End(xlToLeft).Column - 1
colStart = 2
colEnd = 5
For i = colStart To lastColumnAA * 4 Step 4
.Merge
colEnd = colEnd + 4
Dim colEnd As Long
Dim i As Long
colStart = 2
colEnd = 5
.Merge
colEnd = colEnd + 4
