lookup return multiple values
sna
Excel Ver: Excel 365
Post by sna »
Hi there,
I need your input how to lookup a value return multiple outputs.
For example I input 203813 it will populate two accounts...
I attach a template
Note excel 2019
norkaz
Excel Ver: 2013,365
Re: lookup return multiple values
Post by norkaz »
L9
=IFERROR(INDEX(B:B,AGGREGATE(15,6,ROW($C$9:$C$11816)/($K$9=$C$9:$C$11816),ROWS(L$9:L9))),"")
Copy down a column.
M9
=IFERROR(INDEX(F:F,AGGREGATE(15,6,ROW($C$9:$C$11816)/($K$9=$C$9:$C$11816),ROWS(M$9:M9))),"")
Copy down a column.
Bigcat9Excel
Bangkok Thailand
sna
Post by sna »
Thanks .always helpful
